• u4gm Battlefield 6 SOR556 MK2 Accuracy Tips
 #2323  por iiak32484
So, you have got your hands on the SOR-556 MK2 in Battlefield 6, and straight away it feels a bit different. You are not imagining it – this rifle is not built for the usual run-and-gun chaos. It is more like a precision tool, something that rewards patience and careful aim. If you are used to charging into fights, you will need to slow things down and think more like a mid-range marksman. The SOR-556 MK2 shines when you set up in the right spot and pick your shots, and that is where the fun really starts. If you are looking to get the most out of it, even in a Battlefield 6 Bot Lobby, the key is in how you build and use it.
When it comes to loadouts, forget trying to make this thing work in tight corridors – it will lose out to SMGs every time. You want to lean into what it does best: accuracy and bullet speed. For optics, something like the Specter DR 1.5-4x is a solid pick. It gives you a clear view for mid-range fights without clutter. The Vanguard Heavy Barrel is the next must-have. Sure, it slows your aim-down-sights a touch, but the extra bullet velocity and range make every shot count. Under the barrel, the Stalker Angled Grip is a game-changer. It cuts down that first bit of horizontal sway, so your opening shots hit dead-on. And for ammo, go with 77gr High-Velocity Rounds – they make hitting moving targets at range so much easier.
Once you are in the field, positioning is everything. You are not the player storming the objective – you are the one locking down sightlines from cover, punishing anyone who gets caught in the open. Find a ridge, a window, or a bit of cover that lets you control a lane. Let your squad’s faster-firing weapons deal with the messy close fights. Your role is to keep the mid-range clean and force enemies to think twice before crossing open ground.
The real trick with the SOR-556 MK2 is firing discipline. Holding the trigger will just waste its potential. This rifle rewards short, controlled bursts. At longer ranges, tap fire – one shot at a time – so you can reset aim between each. Mid-range? Two or three rounds per burst, then pause. That rhythm keeps your shots tight and your recoil low. Once you get used to it, you will find yourself landing headshots over and over, and it almost feels unfair. Whether you are playing against real opponents or working on Battlefield 6 bot farming, mastering that cadence is what turns the SOR-556 MK2 from a decent rifle into an absolute laser.
