Path of Exile 2 Patch 0.3.1: Skadoosh's Corrupting Cry Warbringer Build
The Corrupting Cry Warbringer build in Path of Exile 2 (PoE 2) patch 0.3.1 is one of Path of Exile 2 Currency the most creative strength-stacking setups in the entire Warlord archetype lineup. Developed by Skadoosh, this build takes full advantage of Seismic Cry, Infernal Cry, and the support gem Corrupting Cry to unleash massive damage over time, screen-wide explosions, and endless totem summons. With the reworked warcry system and the introduction of new charge-generation mechanics, this build combines high damage, durability, and simplicity - all wrapped in a one-button warcry playstyle that feels both powerful and chaotic.
Whether you're starting fresh, upgrading from an endgame setup, or chasing Uber-tier content, this build offers flexibility and consistent scaling through the combination of warcry speed, strength stacking, and clever weapon swapping.
Build Concept and Overview
At its core, the Corrupting Cry Warbringer build revolves around applying Corrupted Blood through Corrupting Cry-supported warcries like Seismic Cry and Infernal Cry. Each cry applies a stack of Corrupted Blood - dealing 25% of your total Strength as physical damage per second for 5 seconds, stacking up to 10 times. This means the build can output 250% of your Strength per second in damage over time, creating devastating screen-wide effects as enemies melt under overlapping stacks.
To further enhance this, the build uses Hateforge, Raging Cry, Roaring Cries, and two Guatelitzi's Soul Core of Endurance charms to produce massive Endurance Charge generation. This allows the summoning of up to 14 Ancestral Warrior Totems back-to-back - effectively maintaining permanent offensive pressure while you warcry your way through mobs and bosses.
In essence, the build is an elegant mix of totem automation and strength-based warcry abuse that thrives on clever Path of Exile 2 Items interactions.
How It Works
The synergy begins with Corrupting Cry - a gem that links to your warcries, causing them to inflict Corrupted Blood. On paper, the setup seems simple, but its power comes from Warcaller's Bellow, the Warbringer ascendancy that completely removes warcry cooldowns. This allows you to spam Seismic Cry continuously, applying stacks of Corrupted Blood nearly instantaneously.
However, the build would struggle with mana and survivability if not for several key passives and item interactions:
Urgent Call and Blood Magic on the passive tree convert warcry mana costs into life, letting you sustain through massive health pools.
Second Wind III unexpectedly interacts with warcries to provide burst life recovery each time you shout.
The high Strength scaling inherently grants +2 Life per point, meaning life cost remains sustainable.
When transitioning into single-target fights, Shockwave Totem, Forge Hammer, and Earthquake take over. The weapon swap mechanic (now instant in 0.3.0+) lets you switch between your totem and shield sets seamlessly - maximizing both damage and defense.
Weapon Set 1 focuses on Seismic Cry and Infernal Cry for damage and charge generation.
Weapon Set 2 focuses on Ancestral Warrior Totem and Shockwave Totem, scaling skill duration and melee damage.
Essentially, you shout, spawn totems, and let the overlapping fissures, jagged ground, and explosions from Shockwave Totem and Forge Hammer detonate everything in range.
Strengths and Weaknesses
Strengths:
One-button, screen-clearing gameplay - massive AoE from warcries.
Passive and automatic damage through Corrupted Blood.
Exploding corpses prevent corpse-based mechanics.
High durability thanks to huge Strength scaling and Endurance Charges.
Cheap to get started - only a few key uniques required.
Works with or without Hateforge (but shines with it).
Weaknesses:
Slow movement speed - the "Warrior life."
Heavy visual lag with 14+ totems active.
Extremely loud due to constant warcries.
Requires manual weapon swap setup for optimal efficiency.
Gear and Stat Priorities
For gearing, your main goals are Strength, Resistances, and Life. Secondary stats like movement speed and armor add quality of life and survivability.
Priority List:
1. +Strength on every possible slot.
2. Maximum Life on armor, boots, and rings.
3. Elemental Resistance capped at 75% (Chaos ideally 65-75%).
4. Movement Speed on boots (at least 20%).
5. Armor and Block Chance scaling for defense.
Key Uniques & Setup:
Hateforge - Enables back-to-back totem summoning with Rage synergy.
From Nothing + Avatar of Fire - Mandatory for accessing Roaring Cries.
Constricting Command - Reduces the surrounding enemy requirement for warcries.
Guatelitzi's Soul Core of Endurance (x2) - Generates Endurance Charges efficiently.
Fortified Location - Ideal amulet anointment for tankiness.
Optional gear like Astramentis or Gold Rings can provide rarity boosts for farming while maintaining the necessary Strength threshold.
Skill Setup
Main Skills (Weapon Set 1):
Seismic Cry (linked to Corrupting Cry, Raging Cry, Infernal Cry)
Fortifying Cry - Adds extra mitigation.
Totem Setup (Weapon Set 2):
Shockwave Totem
Forge Hammer (linked to Jagged Ground I or Rakiata's Flow)
Support Skills:
Charge Regulation - Replaces Dread Banner for consistent uptime.
Earthquake - Provides jagged ground for Shockwave Totem detonations.
Pro Tip:
Hold your Seismic Cry key and tap Ancestral Warrior Totem to maximize totem uptime. Using left-click for Seismic Cry and right-click for Ancestral Warrior Totem is the optimal setup.
Endgame Scaling
At Uber's endgame, the build evolves around Hateforge interactions. You'll maintain a rotation of Raging Cry and Roaring Cries to continuously generate Endurance Charges and spam totems. Weapon swapping lets you drop 10+ totems instantly while still benefiting from shield defenses.
Patch 0.3.1 buffs to warcry gems and the addition of Fortifying Cry further empower this build, while attribute requirement reductions make gem management easier than ever.
Conclusion
Skadoosh's Corrupting Cry Warbringer Build is a masterclass in Path of Exile 2 creativity - combining brute strength with intricate mechanics like Corrupted Blood stacking, instant weapon swaps, and charge-based totem spamming. It's one of the most satisfying builds to pilot, capable of clearing the screen with a single button while remaining durable enough for Uber content.
If you enjoy off-meta builds, explosive visuals, and the feeling of commanding an army of war totems while shouting enemies into oblivion - this is your go-to choice for Patch 0.3.1.
Consider boosting your progress with top-tier gear and currency - you can easily cheap POE2 Currency from eld.gg to fast-track your endgame setup.
How It Works
Strengths:
Weaknesses:
Priority List:
Skill Setup
Shockwave Totem
Support Skills:
Pro Tip:
Endgame Scaling
Conclusion
