Borderlands 4 Items continues the franchise’s tradition of high-octane action, irreverent humor, and a treasure trove of legendary loot. One of the standout items in the game is the Triple Bypass, a unique weapon mod that can drastically change the course of your battle strategies. But obtaining the Triple Bypass is no easy feat. In this guide, we’ll take you step-by-step through the process of acquiring this powerful mod and make sure you’re well-prepared for the journey ahead.
What is the Triple Bypass?
The Triple Bypass is an item mod that enhances your weapons in Borderlands 4, offering a unique set of attributes that can help turn the tide in even the most challenging combat situations. This mod doesn’t just boost raw damage—its strength lies in its ability to modify multiple weapon stats simultaneously, including elemental effects, fire rate, and accuracy. When equipped, the Triple Bypass grants your weapon an insane power boost, making it ideal for taking down tougher enemies, including bosses and elite mobs.
What truly sets the Triple Bypass apart is its synergy with certain weapon types. If you’re using a weapon with high elemental damage or one that benefits from increased accuracy, this mod will unlock its full potential, making your guns feel like they’re part of your character’s true arsenal.
Where to Find the Triple Bypass
While there’s no simple store purchase for the Triple Bypass in Borderlands 4, it’s still fairly accessible—if you know where to look. The mod is found within one of the game’s many vaults, but it requires a series of steps to unlock it. The following guide breaks down the process for acquiring the Triple Bypass in detail:
Step 1: Reach Level 30
Before attempting to acquire the Triple Bypass, make sure your character has reached at least level 30. The mod is designed for mid-to-late-game content, and trying to go after it too early could result in frustration due to the difficulty of the area. Additionally, reaching level 30 ensures that you have access to a wider variety of powerful weapons that the mod can truly enhance.
Step 2: Unlock the “Circuit Breaker” Quest
The Triple Bypass mod is tied to a side mission called “Circuit Breaker,” which becomes available after you’ve completed a major storyline quest. To unlock the mission, head over to the City of Ironclad, a location that opens up around level 30. The NPC who provides this quest is a character named Volt, a former engineer who used to work on the Hyperion circuits but now has an interest in experimenting with weapons tech. Volt will give you the mission to retrieve a special component called the “Circuit Core,” which is a key item for unlocking the Triple Bypass.
Step 3: Survive the Shattered Helix Outpost
The Shattered Helix Outpost is a tough area filled with hostile enemy forces, including the notorious Shocktroopers—advanced enemy soldiers equipped with lightning-infused gear. The key to progressing through this area is knowing how to handle elemental enemies, as many of them have strong resistance to certain damage types.
Step 4: Defeat the Helix Overlord
After you retrieve the Circuit Core, you’ll face off against the Helix Overlord, a massive boss that has the ability to summon additional shock-based minions during the fight. The Overlord is formidable, with a wide array of attacks that can deal significant damage, including an EMP burst that disables shields and slows down movement.
Conclusion
The Triple Bypass is a powerful mod that can significantly enhance your weapons in Borderlands 4 Legendary Items, making it a must-have for players who want to maximize their damage potential. However, obtaining it requires navigating challenging outposts, defeating tough enemies, and taking down a dangerous boss. Once you’ve completed the “Circuit Breaker” quest and acquired the mod, you’ll find that your weapons are even more formidable, ready to take on the toughest foes the game has to offer. Make sure you’re prepared with the right gear, strategy, and mindset—because this mod is well worth the effort!
Conclusion
