• u4gm ARC Raiders Stella Montis Medical Storage Key Walkthrough
  • Una zona en la que podrás hablar de todo lo relacionado con tu C5 AirCross.
 #2315  por Alam560
If you have ever stood in front of the locked Medical Storage at Stella Montis, wondering where the key might be, you are not alone. Plenty of Raiders burn time tearing through desks and lockers inside the main building, only to walk away empty-handed. The trick is, the key is not even in there. It is actually sitting outside, tucked away in a spot you might walk right past if you are sprinting between objectives. Slow down, take a breath, and remember that sometimes the game hides its best rewards in plain sight. This is one of those moments, and if you are after top-tier medical gear, it is worth the detour—especially if you are already thinking about ARC Raiders Items.
Start by turning your back to the Medical Storage door. Face away from the building and head southeast. You do not need to go far—about fifty or sixty metres should do it. Keep your eyes open for signs of trouble, because what you are looking for is a wreck. It is the sort of scene that tells you something went badly wrong, and in this case, it is an overturned medical transport. You will usually spot it wedged against rocks or crumpled into ruined terrain, and if you are lucky, the emergency lights will still be flashing faintly. It is easy to imagine it was either rushing supplies in or trying to evacuate before things fell apart.
When you reach the wreck, you will notice a body slumped against the side of the vehicle. It is a medic who clearly did not make it out. This is where the key is hiding. Check the body’s inventory and you will find the Stella Montis Medical Storage Key right there. No puzzles, no long scavenger hunt—just a quick grab once you know where to look. It is one of those finds that makes you wonder how many players have run right past it without realising.
With the key in hand, jog back to the locked door. The moment you unlock it, you will see why this little trip was worth it. Inside, you can expect a solid stash—advanced medkits, combat stims, and sometimes rare crafting bits for medical gear. It is a perfect resupply point, especially if you are gearing up for a fight with an ARC patrol or heading into a tough mission. And now, the next time you hit Stella Montis, you will know exactly where to go—making it one more edge you have over the Raiders who are still searching the wrong building. If you are looking to boost your loadout even further, you might also want to check out buy ARC Raiders weapons.
