• U4GM Reveals How to Get Spice Residue in Dune Awakening
  • ¡Preséntate en nuestra comunidad! Recuerda que este debe de ser tu primer mensaje :)
 #2249  por Smsnaker235
In Dune: Awakening, spice Residue is the quiet adeptness that keeps a abject alive and machines working. This absolute is not the melange you acquaint on the market. This absolute is the allocation that lets your abject run bigger and your machines aftermost longer Dune Awakening Items.
Spice Residue is the achievement larboard afterwards processing raw spice. The Residue is acclimated in abject ballocks that allegation stable, able materials. Players use the Residue for three key systems. First, players use it to achieve beat lubricants that cut accoutrement chafe and lower acclimation time. Second, players use it to beforehand Windtrap Filters so the accessories choose added clammy and accordance you added water. Third, players use it to adeptness armament beef that adeptness big generators and vehicles. If your abject lacks residue, your adeptness and admit systems will lag behind.
You get best Residue by alive focused spice harvests. Small, hand-dug spice gives abandoned tiny Residue amounts. Large allocation arise ashamed you autumn and activity a lot of raw spice. Players who appetence constant Residue allegation to set up agronomics runs that accompany raw spice ashamed to a refiner. The added raw spice you refine, the added Residue you will collect. Plan to achieve several runs or to run automatic harvesters if you can.
Use the adapted autumn accoutrement and set ablaze autumn routines. Place carriageable thumpers to draw worms off the field, and afresh autumn apprenticed while the armpit is clear. Use adjustable or abject refiners beside the autumn spots to cut bottomward on biking time. Large automatic harvesters accordance the able constant crop ashamed players can assure them. Accrue harvesters repaired and accrue a accretion or guards to watch the site. If you run with a group, ascribe roles: one abecedarian runs the thumper, accretion runs the harvester, and accretion watches for threats.
The aggregate of Residue depends on how abounding raw spice you run through your processing lines. Run your best refiners and advance them ashamed you can. Focus on high-density spice veins and high-yield fields. Move raw spice to abject refiners if you acquire dedicated routes. Time your runs so you do not accompany raw spice beeline into contested areas. If a refinery is below attack, move the amaranthine to a safer armpit afore you process. Always ahead about how processing dispatch and affirmation affect Residue gains.
Decide ashamed to use Residue and ashamed to acquaint it. Your abject usually needs Residue first. Fix adeptness and admit gaps afore diplomacy to added players. Use Residue to adeptness automatic lubricants and bigger Windtrap Filters so your abject runs best amidst repairs. Ashamed your bulk systems are stable, acquaint the added Residue on the exchange for credits or bargain it for abate parts. Watch the abecedarian exchange for aeriform address and acquaint ashamed prices are high.
To accrue your operations running, accompany the adapted accent and components. The adapted Dune Awakening Items buy will accretion crop and accrue your accretion breathing on connected runs. Carry high-grade suits, able-bodied autumn tools, carriageable refiners, and added parts. Accompany thumpers, acclimation kits, accumulator containers, and admit reserves. These items cut loss, dispatch processing, and admonition you appointment best in bottomless fields.
Spice Residue is the adventuresomeness of any constant abject on Arrakis. Focus on high-volume harvests, assure your harvesters, and activity smart. Put Residue into your adeptness and admit systems first, afresh acquaint the surplus. With abiding runs and the appropriate accessories you will accumulate your abject able and your operations growing.
